Command reference
security anti-ransomware volume dry-run
(DEPRECATED) Dry-run anti-ransomware on a volume (DEPRECATED: All fields to this command are deprecated)
The security anti-ransomware volume dry-run command starts anti-ransomware monitoring in the evaluation mode on a volume. Deprecated: This command is no longer supported and may be removed in a future release.
-vserver <vserver name> - Vserver Name
Anti-ransomware monitoring is enabled in the evaluation mode on volumes that match the values for the Vserver and volume parameters. If only one data Vserver exists, you do not need to specify this parameter. Deprecated: This parameter is no longer supported and may be removed in a future release.
-volume <volume name> - Volume Name
Anti-ransomware monitoring is enabled in the evaluation mode on volumes matching the parameter value. Deprecated: This parameter is no longer supported and may be removed in a future release.
