      system services ndmp node-scope-mode on
(DEPRECATED)-Enable NDMP node-scope-mode
This node-scoped NDMP command is deprecated. Node-scoped NDMP functionality may be removed in a future release of Data ONTAP. Use the Vserver-aware "`vserver services ndmp` " command. |
This command puts the NDMP server in the node-scope-mode. In the node-scope-mode, NDMP server has the following behavior:
All NDMP operations are restricted to resources on the node
Vserver-aware NDMP commands are disabled
NDMP authentication falls back to DATA ONTAP 8.1 NDMP authentication scheme
The following example enables node-scope-mode of operation :
cluster1::> system services ndmp node-scope-mode on NDMP node-scope-mode is enabled.
