vserver peer permission modify
Modify the Existing Vserver peer permission
The vserver peer permission modify command is used to modify attributes of the Vserver peer permission relationship. Changes made using this command will only apply to Vserver peer relationships that are created after the Vserver peer permission have been modified. Vserver peer permission is used to give permission to a local Vserver for intercluster Vserver peer relationship creation so that the command vserver peer accept is not required for incoming Vserver peer relationship creation from a remote cluster for that local Vserver.
- -peer-cluster <text>- Peer Cluster Name
Specifies the name of the peer cluster.
- -vserver <text>- Vserver Name
Specifies name of the local Vserver for which you want to modify applications of the Vserver peer permission relationship.
- -applications {snapmirror|flexcache}- Peering Applications
Specifies the applications that can make use of the intercluster Vserver peer relationship.
The following example illustrates how to modify Vserver peer permissions:
cluster1::*> vserver peer permission modify -peer-cluster cluster2 -vserver vs1 -applications snapmirror
 PDFs
PDFs
