snapmirror policy remove-rule
Remove a rule from SnapMirror policy
The snapmirror policy remove-rule command removes a rule from a SnapMirror policy. On the destination of a SnapMirror relationship with snapmirror policy of type vault or mirror-vault , all Snapshot copies with a SnapMirror label matching the rule being removed are no longer processed by SnapMirror and might need to be deleted manually. A snapmirror policy of type vault must have at least one rule if that policy is associated with a SnapMirror relationship. A SnapMirror policy with rules must have at least one rule without a schedule.
-vserver <vserver name>- Vserver Name-
Specifies the Vserver for the SnapMirror policy.
 -policy <sm_policy>- SnapMirror Policy Name-
Specifies the SnapMirror policy name.
 -snapmirror-label <text>- Snapshot Copy Label-
This parameter specifies the rule that is removed from the SnapMirror policy.
The rule for SnapMirror label
sm_createdcannot be removed from SnapMirror policies of typeasync-mirrorormirror-vault.
The following example removes a rule named nightly from a SnapMirror policy named TieredBackup on Vserver vs0.example.com :
vs0.example.com::> snapmirror policy remove-rule -vserver vs0.example.com -policy TieredBackup -snapmirror-label nightly
