The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
vserver http-proxy delete
PDF of this doc site
Creating your file...
Your file is ready
Remove a HTTP Proxy configuration
The vserver http-proxy delete
command deletes an HTTP proxy configuration.
-vserver <vserver>
- Vserver-
Use this parameter to specify the Vserver for which the HTTP proxy configuration is to be deleted.
The following example deletes the HTTP proxy configuration for the Vserver vs0:
cluster1::*> vserver http-proxy delete -vserver vs0
