      vserver http-proxy delete
Remove a HTTP Proxy configuration
The vserver http-proxy delete command deletes an HTTP proxy configuration.
- -vserver <vserver>- Vserver
Use this parameter to specify the Vserver for which the HTTP proxy configuration is to be deleted.
The following example deletes the HTTP proxy configuration for the Vserver vs0:
cluster1::*> vserver http-proxy delete -vserver vs0
 PDFs
PDFs
