ONTAP commands
vserver http-proxy delete
Remove a HTTP Proxy configuration
The vserver http-proxy delete command deletes an HTTP proxy configuration.
-vserver <vserver> - Vserver
Use this parameter to specify the Vserver for which the HTTP proxy configuration is to be deleted.
The following example deletes the HTTP proxy configuration for the Vserver vs0:
cluster1::*> vserver http-proxy delete -vserver vs0
