ONTAP 9.10.1 commands
system node power on
Power nodes on
This command switches on the power of the main controller of the specified node. This command works for a single node only and the full name of the node must be entered exactly.
-node {<nodename>|local} - Node (privilege: advanced)
This parameter specifies the node whose power you want to switch on.
The following example switches on the power of node2.
cluster1::> set advanced
Warning: These advanced commands are potentially dangerous; use them only when
         directed to do so by NetApp personnel.
Do you want to continue? {y|n}: y
cluster1::*>
cluster1::*> system node power on -node node2
cluster1::*>
