volume snapshot rename
Rename a snapshot
The volume snapshot rename command renames a Snapshot copy.
|  | You cannot rename a Snapshot copy that is created as a reference copy during the execution of the volume movecommand. |
- -vserver <vserver name>- Vserver
This specifies the Vserver that contains the volume on which the specified Snapshot copy is to be renamed
- -volume <volume name>- Volume
This specifies the volume that contains the Snapshot copy to be renamed.
- -snapshot <snapshot name>- Snapshot
This specifies the Snapshot copy that is to be renamed.
- -new-name <snapshot name>- Snapshot New Name
This specifies the new name for the Snapshot copy.
- [-force <true>]- Force Rename (privilege: advanced)
If this parameter is specified, the Snapshot copy rename operation is allowed on application tagged volumes. Otherwise, the operation is disallowed on application tagged volumes.
The following example renames a Snapshot copy named vol3_snap on a volume named vol3 and a Vserver named vs0. The Snapshot copy is renamed to vol3_snap_archive.
cluster1::> volume snapshot rename -vserver vs0 -volume vol3 -snapshot vol3_snap -new-name vol3_snap_archive
 PDFs
PDFs
