ONTAP commands
volume snapshot rename
Rename a snapshot
The volume snapshot rename command renames a snapshot.
Note You cannot rename a snapshot that is created as a reference copy during the execution of the volume move command.
-vserver <vserver name> - Vserver
This specifies the Vserver that contains the volume on which the specified snapshot is to be renamed
-volume <volume name> - Volume
This specifies the volume that contains the snapshot to be renamed.
-snapshot <snapshot name> - Snapshot
This specifies the snapshot that is to be renamed.
-new-name <snapshot name> - Snapshot New Name
This specifies the new name for the snapshot.
[-force <true>] - Force Rename (privilege: advanced)
If this parameter is specified, the snapshot rename operation is allowed on application tagged volumes. Otherwise, the operation is disallowed on application tagged volumes.
The following example renames a snapshot named vol3_snap on a volume named vol3 and a Vserver named vs0. The snapshot is renamed to vol3_snap_archive.
cluster1::> volume snapshot rename -vserver vs0 -volume vol3
-snapshot vol3_snap -new-name vol3_snap_archive
