template upload
Upload an existing template to an external server
Use this command to upload an existing template on to an external server.
-name <template name>
- Name of the template-
This parameter specifies the name of the template.
-uri {(ftp|http)://(hostname|IPv4 Address|'['IPv6 Address']')…}
- URI to upload the template-
This parameter specifies the URI to which the template will be uploaded.
The following example uploads a template template1 on to an external server specified in the uri input parameter:
cluster1::*> template upload -name template1 -uri http://www.example.com/mytemplates/
