storage firmware acp show
Display the list of ACP firmware files on the given node
The storage firmware acp show command displays the ACP processor firmware files present on each node.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node {<nodename>|local}]- Node-
Selects the files that match the specified node name.
[-filename <text>]- Storage Firmware File-
Selects the files that match the specified filename.
The following example displays the ACP processor firmware files on each node:
cluster1::> storage firmware acp show
Node: Node1
ACP Firmware Files
ACP-IOM3.0150.AFW.FVF
ACP-IOM3.AFW
ACP-IOM6.0210.AFW
ACP-IOM6.0210.AFW.FVF
Node: Node2
ACP Firmware Files
ACP-IOM3.AFW
ACP-IOM6.0210.AFW
8 entries were displayed.
