      storage firmware acp show
Display the list of ACP firmware files on the given node
The storage firmware acp show command displays the ACP processor firmware files present on each node.
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-node {<nodename>|local}]- Node
Selects the files that match the specified node name.
- [-filename <text>]- Storage Firmware File
Selects the files that match the specified filename.
The following example displays the ACP processor firmware files on each node:
cluster1::> storage firmware acp show
Node: Node1
ACP Firmware Files
                  ACP-IOM3.0150.AFW.FVF
                  ACP-IOM3.AFW
                  ACP-IOM6.0210.AFW
                  ACP-IOM6.0210.AFW.FVF
Node: Node2
ACP Firmware Files
                  ACP-IOM3.AFW
                  ACP-IOM6.0210.AFW
                  8 entries were displayed.
 PDFs
PDFs
