ONTAP commands
storage port modify
Modify a storage port
The storage port modify command modifies the attributes of a storage port.
-node {<nodename>|local} - Node
This parameter specifies the name of the node.
-port <text> - Port
This parameter specifies the name of the port.
[-mode {storage|network}] - Mode
This parameter specifies the usage mode for an Ethernet port - storage or network use. The mode parameter only applies to Ethernet ports that are not dedicated to storage connectivity.
[-force <true>] - Force (privilege: advanced)
This parameter allows the operation to override warnings.
The following example places a nondedicated Ethernet port in storage mode:
cluster1::> storage port show
Speed                           VLAN
Node           Port Type  Mode    (Gb/s) State    Status            ID
cluster1-01
               e0b  ENET  network      - -        -                  -
               e0c  ENET  -          100 enabled  online            30
               e0e  ENET  storage      0 enabled  offline           30
               e0f  ENET  -          100 enabled  online            30
cluster1-02
               e0b  ENET  storage      0 enabled  offline           30
8 entries were displayed.
cluster1::> storage port modify -node cluster1-01 -port e0b -mode storage
Speed                           VLAN
cluster1-01
cluster1-02
