storage port modify
Modify a storage port
The storage port modify command modifies the attributes of a storage port.
-node {<nodename>|local}- Node-
This parameter specifies the name of the node.
-port <text>- Port-
This parameter specifies the name of the port.
[-mode {storage|network}]- Mode-
This parameter specifies the usage mode for an Ethernet port - storage or network use. The mode parameter only applies to Ethernet ports that are not dedicated to storage connectivity.
[-force <true>]- Force (privilege: advanced)-
This parameter allows the operation to override warnings.
The following example places a nondedicated Ethernet port in storage mode:
cluster1::> storage port show
Speed VLAN
Node Port Type Mode (Gb/s) State Status ID
cluster1-01
e0b ENET network - - - -
e0c ENET - 100 enabled online 30
e0e ENET storage 0 enabled offline 30
e0f ENET - 100 enabled online 30
cluster1-02
e0b ENET storage 0 enabled offline 30
8 entries were displayed.
cluster1::> storage port modify -node cluster1-01 -port e0b -mode storage
Speed VLAN
cluster1-01
cluster1-02
