vserver fpolicy show
Display all policies with status
The vserver fpolicy show
command displays status information about all FPolicy policies in the Vserver. The command output depends on the parameter or parameters specified with the command. If you do not specify any parameters, the command displays the following information about all FPolicy policies:
Vserver name
Policy name
Sequence number
Status
You can specify the -fields
parameter to specify which fields of information to display about FPolicy policies.
You can specify the -instance
parameter to display information for all FPolicy policies in a list format.
[-fields <fieldname>,…]
If you specify the -fields <fieldname>, … parameter, the command only displays the fields that you specify.
[-instance ]
If you specify the -instance parameter, the command displays detailed information about all entries.
[-vserver <Vserver Name>]
- Vserver-
If you specify this parameter, the command displays information only about the FPolicy policies for the specified Vserver.
[-policy-name <Policy name>]
- Policy-
If you specify this parameter, the command displays information only about the FPolicy policy that you specify.
[-sequence-number <integer>]
- Sequence Number-
If you specify this parameter, the command displays information only about the FPolicy policy or policies that use the specified sequence-number.
[-status {on|off}]
- Status-
If you specify this parameter, the command displays information only about the FPolicy policy or policies that use the specified status.
[-engine <Engine name>]
- FPolicy Engine-
If you specify this parameter, the command displays information only about the FPolicy policy or policies that use the specified engine.
The following example displays the information about FPolicy policies on the cluster using the vserver fpolicy show
command.
cluster1::> vserver fpolicy show Sequence Vserver Policy Name Number Status Engine ----------------------- -------------------------- -------- --------- --------- FPolicy cserver_policy - off eng1 vs1.example.com v1p1 - off eng2 vs1.example.com v1p2 - off native vs1.example.com v1p3 - off native vs1.example.com cserver_policy - off eng1 vs2.example.com v1p1 3 on native vs2.example.com v1p2 1 on eng3 vs2.example.com cserver_policy 2 on eng1 8 entries were displayed.
