Command reference
vserver fpolicy show
Display all policies with status
The vserver fpolicy show command displays status information about all FPolicy policies in the Vserver. The command output depends on the parameter or parameters specified with the command. If you do not specify any parameters, the command displays the following information about all FPolicy policies:
  • Vserver name
  • Policy name
  • Sequence number
  • Status
You can specify the -fields parameter to specify which fields of information to display about FPolicy policies.
You can specify the -instance parameter to display information for all FPolicy policies in a list format.
{ [-fields <fieldname>,…​]
If you specify the -fields <fieldname>, …​ parameter, the command only displays the fields that you specify.
| [-instance ] }
If you specify the -instance parameter, the command displays detailed information about all entries.
[-vserver <Vserver Name>] - Vserver
If you specify this parameter, the command displays information only about the FPolicy policies for the specified Vserver.
[-policy-name <Policy name>] - Policy
If you specify this parameter, the command displays information only about the FPolicy policy that you specify.
[-sequence-number <integer>] - Sequence Number
If you specify this parameter, the command displays information only about the FPolicy policy or policies that use the specified sequence-number.
[-status {on|off}] - Status
If you specify this parameter, the command displays information only about the FPolicy policy or policies that use the specified status.
[-engine <Engine name>] - FPolicy Engine
If you specify this parameter, the command displays information only about the FPolicy policy or policies that use the specified engine.
The following example displays the information about FPolicy policies on the cluster using the vserver fpolicy show command.
cluster1::> vserver fpolicy show
                                                               Sequence
            Vserver                 Policy Name                  Number  Status      Engine
            FPolicy                 cserver_policy             -         off         eng1
            vs1.example.com         v1p1                       -         off         eng2
            vs1.example.com         v1p2                       -         off         native
            vs1.example.com         v1p3                       -         off         native
            vs1.example.com         cserver_policy             -         off         eng1
            vs2.example.com         v1p1                       3         on          native
            vs2.example.com         v1p2                       1         on          eng3
            vs2.example.com         cserver_policy             2         on          eng1
            8 entries were displayed.
