ONTAP commands
vserver check lif-multitenancy show-results
Show the results of the latest multitenancy network run
You can view detailed information about the latest completed run, or the run for a Vserver.
  • Vserver - name of vserver run was for
  • Severity - severity of the message which is failure, warning, or info.
    Failures are problems that need fixed. Warnings are potential
    problems that may need to be fixed. Values are "failure", "warning" or "info".
  • Service - name of service that is being checked for connectivity
  • Address - address of server configured for the above service that is being
    checked for connectivity.
  • LIF - the LIF a successful connectivity check to the above server was made from
  • Connected - true of there is connectivity, false if there is not
  • Status - additional information useful for resolving issues
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <vserver>] - Vserver
Selects the messages matching the specified Vserver
[-severity <text>] - Severity
Selects the messages matching the specified severity of failure, warning, and info.
[-service <text>] - Service Name
Selects the messages matching the specified service.
[-address <text>] - Address of Server
Selects the messages matching the specified address.
[-lif <lif-name>] - Logical Interface
Selects the messages matching the specified LIF.
[-connected {yes|no}] - Vserver Connectivity
Selects the messages matching the specified connectivity.
[-status <text>] - Additional Information
Selects the messages matching the specified search criteria.
Runs that are successful will not have any content.
cluster1::> vserver check lif-multitenancy show-results -vserver vs0
     This table is currently empty.
Runs that fail display each failure that needs to be fixed.
                                        Network      Logical
     Vserver     Severity  Service      Address      Interface  Connected  Status
     vs0
                 warning   -            -            vs0_lif1   -          operationally down
                 warning   -            -            vs0_lif2   -          operationally down
                 failure   DNS          10.98.200.20
                                                     -          no         cache
                 failure   NIS domain   10.98.13.53  -          no         cache
     4 entries were displayed.
