vserver check lif-multitenancy show-results
(DEPRECATED)-Show the results of the latest multitenancy network run
|  | This command is deprecated and may be removed in a future release of Data ONTAP. |
You can view detailed information about the latest completed run, or the run for a Vserver.
Vserver - name of vserver run was for
Severity - severity of the message which is failure, warning, or info.
 Failures are problems that need fixed. Warnings are potential
 problems that may need to be fixed. Values are "failure", "warning" or "info".
Service - name of service that is being checked for connectivity
Address - address of server configured for the above service that is being
 checked for connectivity.
LIF - the LIF a successful connectivity check to the above server was made from
Connected - true of there is connectivity, false if there is not
Status - additional information useful for resolving issues
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-vserver <vserver>]- Vserver
Selects the messages matching the specified Vserver
- [-severity <text>]- Severity
Selects the messages matching the specified severity of failure, warning, and info.
- [-service <text>]- Service Name
Selects the messages matching the specified service.
- [-address <text>]- Address of Server
Selects the messages matching the specified address.
- [-lif <lif-name>]- Logical Interface
Selects the messages matching the specified LIF.
- [-connected {yes|no}]- Vserver Connectivity
Selects the messages matching the specified connectivity.
- [-status <text>]- Additional Information
Selects the messages matching the specified search criteria.
Runs that are successful will not have any content.
cluster1::> vserver check lif-multitenancy show-results -vserver vs0
     This table is currently empty.
Runs that fail display each failure that needs to be fixed.
                                        Network      Logical
     Vserver     Severity  Service      Address      Interface  Connected  Status
     vs0
                 warning   -            -            vs0_lif1   -          operationally down
                 warning   -            -            vs0_lif2   -          operationally down
                 failure   DNS          10.98.200.20
                                                     -          no         cache
                 failure   NIS domain   10.98.13.53  -          no         cache
     4 entries were displayed.
 PDFs
PDFs
