vserver check lif-multitenancy show-results
PDF of this doc site
Creating your file...
(DEPRECATED)-Show the results of the latest multitenancy network run
This command is deprecated and may be removed in a future release of Data ONTAP. |
You can view detailed information about the latest completed run, or the run for a Vserver.
Vserver - name of vserver run was for
Severity - severity of the message which is failure, warning, or info.
Failures are problems that need fixed. Warnings are potential
problems that may need to be fixed. Values are "failure", "warning" or "info". -
Service - name of service that is being checked for connectivity
Address - address of server configured for the above service that is being
checked for connectivity. -
LIF - the LIF a successful connectivity check to the above server was made from
Connected - true of there is connectivity, false if there is not
Status - additional information useful for resolving issues
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-vserver <vserver>]
- Vserver-
Selects the messages matching the specified Vserver
[-severity <text>]
- Severity-
Selects the messages matching the specified severity of failure, warning, and info.
[-service <text>]
- Service Name-
Selects the messages matching the specified service.
[-address <text>]
- Address of Server-
Selects the messages matching the specified address.
[-lif <lif-name>]
- Logical Interface-
Selects the messages matching the specified LIF.
[-connected {yes|no}]
- Vserver Connectivity-
Selects the messages matching the specified connectivity.
[-status <text>]
- Additional Information-
Selects the messages matching the specified search criteria.
Runs that are successful will not have any content.
cluster1::> vserver check lif-multitenancy show-results -vserver vs0 This table is currently empty.
Successful runs made with -verbose true will show the LIF used to Ping the nework address from.
cluster1::> vserver check lif-multitenancy show-results -vserver vs0 Network Logical Vserver Severity Service Address Interface Connected Status ---------- -------- ----------- ----------- --------- ---------- ------- vs0 info DNS 10.98.200.20 vs0_lif1 yes ping info NIS domain 10.98.13.53 vs0_lif1 yes ping 2 entries were displayed.
Runs that fail display each failure that needs to be fixed.
cluster1::> vserver check lif-multitenancy show-results -vserver vs0 Network Logical Vserver Severity Service Address Interface Connected Status ---------- -------- ----------- ----------- --------- ---------- ------- vs0 warning - - vs0_lif1 - operationally down warning - - vs0_lif2 - operationally down failure DNS 10.98.200.20 - no cache failure NIS domain 10.98.13.53 - no cache 4 entries were displayed.
