network bgp peer-group show
Display BGP peer groups information
The network bgp peer-group show command displays the BGP peer groups configuration.
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-ipspace <IPspace>]- IPspace Name
This parameter selects peer groups that match the specified IPspace.
- [-peer-group <text>]- Peer Group Name
This parameter selects peer groups that match the specified name.
- [-bgp-lif <lif-name>]- BGP LIF
This parameter selects peer groups that match the specified BGP Interface.
- [-peer-address <IP Address>]- Peer Router Address
This parameter selects peer groups that match the specified peer router address.
- [-peer-asn <integer>]- Peer Router Autonomous number
This parameter selects peer groups that match the specified autonomous system number.
- [-state <BGP Session State>]- Peer Group State
This parameter selects peer groups that match the specified BGP session state.
- [-bgp-node <nodename>]- BGP LIF Node
This parameter selects peer groups that match the specified bgp-nodevalue. This value is calculated based on the current node of the corresponding BGP LIF.
- [-bgp-port <netport>]- BGP LIF Port
This parameter selects peer groups that match the specified bgp-portvalue. This value is calculated based on the current port of the associated BGP LIF.
- [-route-preference <integer>]- Route Preference
This parameter selects peer groups that match the specified route preference value.
- [-asn-prepend-type <ASN Prepend type>]- ASN prepend type (privilege: advanced)
This parameter selects peer groups that match the specified asn-prepend-typevalue. The possible values arelocal-asnandpeer-asn.
- [-asn-prepend-count <integer>]- ASN prepend count (privilege: advanced)
This parameter selects peer groups that match the specified asn-prepend-countvalue.
- [-community <BGP community>,…]- BGP Community (privilege: advanced)
This parameter selects peer groups that match the specified communityvalue.
- [-med <integer>]- Multi Exit Discriminator (privilege: advanced)
This parameter selects peer groups that match the specified med value.
- [-use-peer-as-next-hop {true|false}]- Use Peer Address As Next Hop
This parameter selects peer groups that match the specified use-peer-as-next-hop value.
cluster1::> network bgp peer-group show
    IPspace: Default
    Peer        Local BGP Peer router                      Autonomous
    Group       Interface Address/subnet    state          Number     Node   Port
    gp1         bgp_lif1  10.0.5.37         up                     10 node1  e1a
    gp2         bgp_lif2  10.0.6.38         up                     12 node1  e2a
 PDFs
PDFs
