network bgp peer-group show
Display BGP peer groups information
The network bgp peer-group show
command displays the BGP peer groups configuration.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-ipspace <IPspace>]
- IPspace Name-
This parameter selects peer groups that match the specified IPspace.
[-peer-group <text>]
- Peer Group Name-
This parameter selects peer groups that match the specified name.
[-bgp-lif <lif-name>]
- BGP LIF-
This parameter selects peer groups that match the specified BGP Interface.
[-peer-address <IP Address>]
- Peer Router Address-
This parameter selects peer groups that match the specified peer router address.
[-peer-asn <integer>]
- Peer Router Autonomous number-
This parameter selects peer groups that match the specified autonomous system number.
[-state <BGP Session State>]
- Peer Group State-
This parameter selects peer groups that match the specified BGP session state.
[-bgp-node <nodename>]
- BGP LIF Node-
bgp-node
value. This value is calculated based on the current node of the corresponding BGP LIF. [-bgp-port <netport>]
- BGP LIF Port-
bgp-port
value. This value is calculated based on the current port of the associated BGP LIF. [-route-preference <integer>]
- Route Preference-
This parameter selects peer groups that match the specified route preference value.
[-asn-prepend-type <ASN Prepend type>]
- ASN prepend type (privilege: advanced)-
asn-prepend-type
value. The possible values arelocal-asn
andpeer-asn
. [-asn-prepend-count <integer>]
- ASN prepend count (privilege: advanced)-
asn-prepend-count
value. [-community <BGP community>,…]
- BGP Community (privilege: advanced)-
community
value. [-med <integer>]
- Multi Exit Discriminator (privilege: advanced)-
This parameter selects peer groups that match the specified med value.
[-use-peer-as-next-hop {true|false}]
- Use Peer Address As Next Hop-
This parameter selects peer groups that match the specified use-peer-as-next-hop value.
cluster1::> network bgp peer-group show IPspace: Default Peer Local BGP Peer router Autonomous Group Interface Address/subnet state Number Node Port ---------- --------- ----------------- -------------- ---------- ------ ----- gp1 bgp_lif1 10.0.5.37 up 10 node1 e1a gp2 bgp_lif2 10.0.6.38 up 12 node1 e2a
