security anti-ransomware volume workload-behavior show
Display information about the volume's workload-behavior learnt by the analytics algorithm
This security anti-ransomware volume workload-behavior show displays the workload characteristics observed by Anti-ransomware analytics engine.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. -vserver <vserver name>- Vserver Name-
This parameter specifies the Vserver on which the volume is located.
-volume <volume name>- Volume Name-
This parameter specifies the name of the volume whose workload details are to be shown.
[-file-extensions-included <text>,…]- File Extensions Expected in the Workload-
This parameter displays the list of extensions observed by Anti-ransomware.
The folowing example shows a sample output for this command:
clus1::>> security anti-ransomware volume workload-behavior show -vserver vs1 -volume testvol Vserver : vsa Volume : testvol File Extensions Included : pdf, doc, txt
