statistics samples show
PDF of this doc site
Creating your file...
Display statistics samples
This command displays information about the samples that you created using the statistics start command.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-describe ]
(privilege: advanced) } -
Displays detailed information about each sample.
[-vserver <vserver name>]
- Vserver (privilege: advanced)-
Selects the samples that match this parameter value. If you omit this parameter, the command displays details for all samples.
[-sample-id <text>]
- Sample Identifier (privilege: advanced)-
Selects the samples that match this parameter value. If you do not specify this parameter, the command will display information about all the samples in the cluster.
The following example displays information for sample "smpl_1":
cluster1::*> statistics samples show -sample-id smpl_1 Vserver Sample ID Start Time Stop Time Status ---------------- -------------------- -------------- -------------- ---------- cluster-d1 smpl_1 09/13 18:06:46 - Ready
The following example displays detailed information for sample "smpl_1":
cluster1::*> statistics samples show -sample-id smpl_1 -describe Vserver: vs1 Sample ID: smpl_1 Object: processor Instance: - Counter: - Start Time: 09/13 18:06:46 Stop Time: - Status: Ready - - Privilege: admin
