ONTAP commands
statistics samples show
Display statistics samples
This command displays information about the samples that you created using the statistics start command.
[-fields <fieldname>,…​]
| [-describe ] (privilege: advanced) }
Displays detailed information about each sample.
[-vserver <vserver name>] - Vserver (privilege: advanced)
Selects the samples that match this parameter value. If you omit this parameter, the command displays details for all samples.
[-sample-id <text>] - Sample Identifier (privilege: advanced)
Selects the samples that match this parameter value. If you do not specify this parameter, the command will display information about all the samples in the cluster.
The following example displays information for sample "smpl_1":
cluster1::*> statistics samples show -sample-id smpl_1
Vserver          Sample ID            Start Time     Stop Time      Status
 cluster-d1       smpl_1               09/13 18:06:46 -              Ready
The following example displays detailed information for sample "smpl_1":
cluster1::*> statistics samples show -sample-id smpl_1 -describe
Vserver: vs1
 Sample ID: smpl_1
    Object: processor
  Instance: -
   Counter: -
Start Time: 09/13 18:06:46
 Stop Time: -
    Status: Ready       - -
 Privilege: admin
