system ha interconnect link on
PDF of this doc site
Creating your file...
Turn on the interconnect link
The system ha interconnect link on
command turns on the specified link on the high-availability interconnect device. For the nodes in the cluster with two external high-availability interconnect links, you must specify the link number (0-based) to turn on the specified link. For the nodes in the cluster with interconnect links over the backplane, you must specify the link number 1 to turn on the link.
-node <nodename>
- Node (privilege: advanced)-
This mandatory parameter specifies the node on which the interconnect link is to be turned on. The value "local" specifies the current node.
-link {0|1}
- Link (privilege: advanced)-
This mandatory parameter specifies the interconnect link number (0-based) to turn on.
The following example displays output of the command on the nodes with a single interconnect link or nodes with interconnect links over the backplane:
cluster1::*> system ha interconnect link on -node ic-f3250-02 -link 0 Error: command failed: Invalid link value 0. Specify 1. cluster1::*> system ha interconnect link on -node ic-f3250-02 -link 1
The following example displays output of the command on the nodes with two interconnect links connected externally:
cluster1::*> system ha interconnect link on -node ic-f3250-02 -link 0 cluster1::*> system ha interconnect link on -node ic-f3250-02 -link 1
