volume file fingerprint show
Display fingerprint operation status
The volume file fingerprint show command returns information for one or several fingerprint operations. This command requires either -session-id or -vserver and -volume .
{ [-fields <fieldname>,…​]
| [-instance ] }
[-session-id <integer>] - Session ID of Fingerprint Operation
If this parameter is specified, the command returns the progress of the fingerprint operation of the specified session-id. The session-id is a unique identifier for the fingerprint operation that is returned when the fingerprint operation is started on a file.
[-vserver <vserver name>] - Vserver
If this parameter is specified, -volume must also be specified. When queried with -vserver and -volume , the command returns the progress of all the fingerprint operations running on that particular volume.
[-volume <volume name>] - Volume Name
If this parameter is specified, -vserver must also be specified. When queried with -vserver and -volume , the command returns the progress of all the fingerprint operations running on that particular volume.
[-file </vol/<volume name>/<file path>>] - File Path
If this parameter is specified, the command returns the progress of all fingerprint operations on the specified file.
[-operation-status {Unknown|In-Progress|Failed|Aborting|Completed}] - Operation Status
If this parameter is specified, the command returns the progress of all fingerprint operations with matching status value.
[-progress-percentage <integer>] - Progress Percentage
If this parameter is specified, the command returns the progress of all fingerprint operations with matching progress percentage value.
The following example displays the progress of all the fingerprint operations running on volume nfs_slc :
cluster1::> volume file fingerprint show -vserver vs0 -volume nfs_slc
        Progress
File-Path                               Session-ID         Status    Percentage
/vol/nfs_slc/worm                       17104897           Completed        100
/vol/nfs_slc/worm_appedable             17104898           Completed        100
/vol/nfs_slc/regular                    17104899           In-Progress       30
3 entries were displayed.
