volume transition-prepare-to-downgrade
PDF of this doc site
Creating your file...
Verifies that there are no volumes actively transitioning from 7-mode to clustered Data ONTAP, and configures the transition feature for downgrade.
The volume transition-prepare-to-downgrade
command is used to verify that a volume is not currently being transitioned from 7-Mode to clustered Data ONTAP. This check must be done before reverting or downgrading a node.
The following example executes the volume transition-inactive-verify
command during active volume transitions.
cluster1::*> volume transition-prepare-to-downgrade
Error: command failed: Downgrade cannot proceed because one or more volumes are transitioning from 7-Mode to clustered Data ONTAP.
You must complete or cancel all transitions. View the transitioning volumes that are preventing the downgrade by using the (privilege: advanced) command "lun transition show -status active -fields vserver, volume".
To complete a transition, break the SnapMirror transition relationship using the command "snapmirror break -destination-path <destination-path>".
For detailed information about transitioning, refer to the "7-Mode Data Transition Using SnapMirror" guide.
To cancel a transition, contact technical support.
