vserver migrate start
PDF of this doc site
Creating your file...
Start the Vserver migrate operation
This command starts the migration of a Vserver from one cluster to another. This has to be run on the destination cluster, i.e. the cluster where the Vserver is intended to migrate. The source cluster from where the Vserver is to be migrated is specified in the command.
-vserver <vserver name>
- Vserver Name-
Name of the Vserver which needs to be migrated.
-source-cluster <Cluster name>
- Source Cluster Name-
Name of the source cluster.
[-check-only {true|false}]
- Check if migrate can be done-
Runs the prechecks and tells if the Vserver migrate operation can be started or not.
[-ipspace <IPspace>]
- Destination cluster IPspace Name for vserver-
Name of the IPspace in the destination cluster.
[-aggr-list <aggregate name>,…]
- Aggregate list-
Provide the list of aggregates where the volumes will be created in the destination cluster.
[-auto-cutover {true|false}]
- Automatically cutover when ready-
This parameter specifies if the Vserver migrate operation should cutover automatically when ready. The default setting is true.
[-auto-source-cleanup {true|false}]
- Automatically cleanup the source vserver after cutover-
This parameter is to specify if the Vserver migrate operation should cleanup the source Vserver automatically. Setting the parameter requires diagnostic privilege. The default setting is true.
cluster1::> vserver migrate start -vserver test -source-cluster cluster-22 -ipspace ips1 -check-only true -aggr-list aggr1,aggr2 -auto-cutover false
