vserver services ndmp log start
Start logging for the specified NDMP session
This command is used to start logging on an active NDMP session on a vserver.
-vserver <vserver name>- Vserver (privilege: advanced)-
This parameter specifies the name of the Vserver.
 -session-id <text>- Session Identifier (privilege: advanced)-
This parameter specifies the NDMP session-id on which logging needs to be started.
 -filter <text>- Level Filter (privilege: advanced)-
Use this parameter to specify the filter for a particular session ID. This parameter controls the NDMP modules for which logging is to be enabled. This parameter can take five values. They are as follow :
all,none,normal,backendor"filter-expression". The default value for this isnone.-
allturns on logging for all modules. -
nonedisables logging for all modules. -
normalis a short cut parameter that enables logging for all modules exceptverboseandio_loop. The equivalent filter string isall-verbose-io_loop -
backendis a short cut parameter that enables logging for all modules exceptverbose,io_loop,ndmpsandndmpd. The equivalent filter string isall-verbose-io_loop-ndmps-ndmpp -
(filter-expression)is a combination of one or more modules for which logs needs to be enabled. Multiple module names can be combined using following operators : -
-to remove the given module from the list of specified modules in the filter string. For example the filterall-ndmppwill enable logging for all modules but notndmpp. -
^to add the given module or modules to the list of modules specified in the filter string. For example the filterndmppmoverdatawill enable logging forndmpp,moveranddata.
The possible module names and a brief description is given below:
+--------------+-------------------------------------+ | Modules | Description | +--------------+-------------------------------------+ | verbose | verbose message | | io | I/O process loop | | io_loop | I/O process loop verbose messages | | ndmps | NDMP service | | ndmpp | NDMP Protocol | | rpc | General RPC service | | fdc_rpc | RPC to FC driver service | | auth | Authentication | | mover | NDMP MOVER (tape I/O) | | data | NDMP DATA (backup/restore) | | scsi | NDMP SCSI (robot/tape ops) | | bkup_rpc | RPC to Backup service client | | bkup_rpc_s | RPC to Backup service server | | cleaner | Backup/Mover session cleaner | | conf | Debug configure/reconfigure | | dblade | Dblade specific messages | | timer | NDMP server timeout messages | | vldb | VLDB service | | smf | SMF Gateway messages | | vol | VOL OPS service | | sv | SnapVault NDMP extension | | common | NDMP common state | | ext | NDMP extensions messages | | sm | SnapMirror NDMP extension | | ndmprpc | NDMP Mhost RPC server | +--------------+-------------------------------------+
The following example shows how to start logging on a specific NDMP session 1000:35512, running on vserver cluster1-01 with filter all.
cluster1::*> vserver services ndmp log start -vserver cluster1-01 -session-id 1000:35512 -filter all
