volume file clone deletion remove-extension
Remove unsupported file extensions for clone delete
The `volume file clone deletion remove-extension ` command can be used to remove the existing file extensions that are no longer supported for clone delete.
-vserver <vserver name> - Vserver Name
Name of the vserver.
-volume <volume name> - Volume Name
Name of the volume.
[-extensions <text>] - Unsupported Extensions for Clone Delete
List of unsupported file extensions for clone delete.
The following example removes the existing unsupported vmdk, vhd file extensions to volume vol1 of vserver vs1 .
cluster1::> volume file clone deletion remove-extension -vserver vs1 -volume vol1 -extensions vmdk,vhd
