The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
job private stop
PDF of this doc site
Creating your file...
Your file is ready
Stop a job
The job private stop
command stops a running private job. A private job is a job that is associated with a specific node and does not use cluster facilities. A stopped job cannot be restarted.
-node {<nodename>|local}
- Node (privilege: advanced)-
This specifies the node on which the job is running.
-id <integer>
- Job ID (privilege: advanced)-
This specifies the numeric ID of the job that is to be stopped.
[-vserver <vserver name>]
- Owning Vserver (privilege: advanced)-
Use this parameter to specify the name of the Vserver that owns the job.
The following example stops a private job with the ID 416 on a node named node0:
cluster1::*> job private stop -node node0 -id 416
