job private stop
Stop a job
The job private stop
command stops a running private job. A private job is a job that is associated with a specific node and does not use cluster facilities. A stopped job cannot be restarted.
-node {<nodename>|local}
- Node (privilege: advanced)-
This specifies the node on which the job is running.
-id <integer>
- Job ID (privilege: advanced)-
This specifies the numeric ID of the job that is to be stopped.
[-vserver <vserver name>]
- Owning Vserver (privilege: advanced)-
Use this parameter to specify the name of the Vserver that owns the job.
The following example stops a private job with the ID 416 on a node named node0:
cluster1::*> job private stop -node node0 -id 416
