statistics cache flash-pool show
Flash pool throughput metrics
This command continuously displays performance data for flash pool caches at a regular interval. The command output displays data in the following columns:
Aggregate - aggregate name.
Vserver - vserver name.
Volume - volume name.
Read Hit - percent of IOs serviced from a cache level.
Write Hit - percent of IOs serviced from a cache level.
Cache Used - SSD cache blocks used.
Read Blocks - read blocks.
Write Blocks - write blocks.
Rejects - cache rejects.
[-aggregate <text>]- Aggregate-
Selects the aggregate for which you want to display performance data.
 [-vserver <vserver name>]- Vserver-
Selects the vserver for which you want to display performance data.
 [-volume <text>]- Volume-
Selects the volume for which you want to display performance data.
 [-sort-key <text>]- Column to Sort By-
If this parameter is specified, the command displays statistics sorted by the specified column.
 -interval <integer>- Interval-
Specifies, in seconds, the interval between statistics updates. The default setting is 5 seconds.
 -iterations <integer>- Iterations-
Specifies the number of iterations the command runs before terminating. The default setting is 1. If the number is 0 (zero), the command continues to run until you interrupt it by pressing Ctrl-C.
 -max <integer>- Maximum Number of Instances-
Specifies the maximum number of flash pools to display. The default setting is 25.
The following example displays flash pool statistics:
cluster1::> statistics cache flash-pool show
cluster1 : 12/31/2013 16:00:04
Read Write
                               Hit   Hit       Cache    Read   Write
   Aggregate  Vserver  Volume  (%)   (%)        Used  Blocks  Blocks Rejects
       aggr1        - -total-    0     0           0       0       0       0
       aggr2      vs1    vol1    0     0           0       0       0       0
