The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
system node nfs usage show
PDF of this doc site
Creating your file...
Your file is ready
Show NFS usage in the local node
The `system node nfs usage show ` command displays the NFS usage information in the local node. The display output shows the number of RPC calls received per protocol on the local node. Usage is collected whenever there is any NFS traffic. These values are not persistent and will reset when the node reboots.
The following example displays the NFS usage information that does not have any NFS usage.
::*> system node nfs usage show Node: node1 v3: 0 v4: 0
The following example displays the NFS usage information with v3 usage.
::*> system node nfs usage show Node: node1 v3: 5 v4: 0
The following example displays the NFS usage information with v4 usage.
::*> system node nfs usage show Node: node1 v3: 0 v4: 14
