      system node nfs usage show
Show NFS usage in the local node
The `system node nfs usage show ` command displays the NFS usage information in the local node. The display output shows the number of RPC calls received per protocol on the local node. Usage is collected whenever there is any NFS traffic. These values are not persistent and will reset when the node reboots.
The following example displays the NFS usage information that does not have any NFS usage.
::*> system node nfs usage show
    Node: node1
      v3: 0
      v4: 0
The following example displays the NFS usage information with v3 usage.
    Node: node1
      v3: 5
      v4: 0
The following example displays the NFS usage information with v4 usage.
    Node: node1
      v3: 0
      v4: 14
