ONTAP 9.10.1 commands
storage shelf drawer show-slot
Display a map between bay number and drawer/slot number
The storage shelf drawer show-slot command maps each drawer and slot number to the corresponding bay number.
{ [-fields <fieldname>,…​]
Displays the specified fields in column style output.
| [-instance ]
Displays all slot information.
[-shelf <text>] - Shelf Name
Displays the slots in the shelf that matches the specified shelf name.
[-bay <integer>] - Bay Number
Displays the slots that have the specified bay number.
[-node {<nodename>|local}] - Node Name
Displays the slots that are present for the specified node.
[-drawer <integer>] - Drawer Number
Displays the slots in the drawers that match the specified drawer number.
[-slot <integer>] - Slot Number
Displays the slots that match the specified slot number.
[-is-installed {yes|no}] - Is Disk Installed
Displays the slots that have a disk installed.
The following example displays the mapping from drawer and slot number to bay number:
cluster1::> storage shelf drawer show-slot
Shelf  Drawer  Slot  Bay  Installed?
     2.5
                1
                      0    0  yes
                      1    1  no
                      2    2  no
                      3    3  yes
                      4    4  no
                      5    5  no
                      6    6  yes
                      7    7  no
                      8    8  no
                      9    9  yes
                     10   10  no
                     11   11  no
                2
                      0   12  yes
                      1   13  no
                      2   14  no
                      3   15  yes
                      4   16  no
                      5   17  no
                      6   18  yes
                      7   19  no
                      8   20  no
                      9   21  yes
                     10   22  no
                     11   23  no
                3
                      0   24  yes
                      1   25  no
                      2   26  no
                      3   27  yes
                      4   28  no
                      5   29  no
                      6   30  yes
                      7   31  no
                      8   32  no
                      9   33  yes
                     10   34  no
                     11   35  no
                4
                      0   36  yes
                      1   37  no
                      2   38  no
                      3   39  yes
                      4   40  yes
                      5   41  no
                      6   42  yes
                      7   43  no
                      8   44  no
                      9   45  yes
                     10   46  no
                     11   47  no
                5
                      0   48  yes
                      1   49  no
                      2   50  no
                      3   51  yes
                      4   52  no
                      5   53  no
                      6   54  yes
                      7   55  no
                      8   56  no
                      9   57  yes
                     10   58  no
                     11   59  no
    60 entries were displayed.
    cluster1::>
