security saml-sp modify
Modify SAML service provider authentication
The security saml-sp modify
command modifies the Security Assertion Markup Language (SAML) Service Provider (SP) configuration for single sign-on authentication. This command is used to enable or disable an existing SAML SP, security saml-sp modify
respectively.-is-enabled
`true or
false`
This command will check the validity of the current SAML SP configuration before enabling the SP. Also, it is necessary to use this command with the -is-enabled
parameter can be modified.`false
parameter prior to deleting an existing SAML SP configuration. SAML SP can only be disabled in this way by a password authenticated console application user or from a SAML authenticated command interface. The delete command must be used if the SAML configuration settings are to be changed, as only the `is-enabled
This may restart the web server. Any HTTP/S connections that are active may be disrupted. |
[-is-enabled {true|false}]
- SAML Service Provider Enabled-
Use this paramater to enable or disable the SAML SP.
The following example enables SAML SP:
cluster1::> security saml-sp modify -is-enabled true cluster1::>
