system configuration recovery cluster sync
- PDF of this doc site
Creating your file...
Your file is ready
Sync a node with cluster configuration
The system configuration recovery cluster sync
command synchronizes a node with the cluster configuration. Only use this command to recover a node from a disaster. Because this synchronization can overwrite critical cluster information, and will restart the node you specify, you are required to confirm this command before it executes.
-node {<nodename>|local}
- Node to Synchronize (privilege: advanced)-
Use this parameter to specify the name of the node to synchronize with the cluster.
The following example shows the synchronization of the node node2
to the cluster configuration.
cluster1::*> system configuration recovery cluster sync -node node2 Warning: This command will synchronize node "node2" with the cluster configuration, potentially overwriting critical cluster configuration files on the node. This feature should only be used to recover from a disaster. Do not perform any other recovery operations while this operation is in progress. This command will cause all the cluster applications on node "node2" to restart, interrupting administrative CLI and Web interface on that node. Do you want to continue? {y|n}: y All cluster applications on node "node2" will be restarted. Verify that the cluster applications go online.
