ONTAP 9.10.1 commands
storage tape show-media-changer
Display information about media changers
This storage tape show-media-changer command displays information about media changers attached to the cluster. By default, this command displays the following information about all media changers:
  • Device ID of media changer
  • Description of media changer
  • World Wide Node Name of media changer
  • World Wide Port Name of media changer
  • Serial number of media changer
  • Media changer errors
  • Node to which the media changer is attached
  • Initiator port which hosts the media changer
  • Alias name of media changer
  • Operational state of media changer
  • Functional status of media changer
{ [-fields <fieldname>,…​]
| [-instance ] }
[-device-id <text>] - Device ID
Selects the media changer with the specified device ID.
[-node {<nodename>|local}] - Node
Displays detailed information about media changers on the specified node.
[-description <text>] - Description
Selects the media changers with the specified description.
[-alias-name <text>] - Alias Name
Selects the media changer with the specified alias name.
[-wwnn <text>] - World Wide Node Name
Selects the media changers with the specified World Wide Node Name.
[-wwpn <text>] - World Wide Port Name
>Selects the media changer with the specified World Wide Port Name.
[-serial-number <text>] - Serial Number
Selects the media changer with the specified serial number.
[-device-if-type {unknown|fibre-channel|SAS|pSCSI}] - Device If Type
Selects the media changers with the specified interface type.
[-device-state {unknown|available|ready-write-enabled|ready-write-protected|offline|in-use|error|reserved-by-another-host|normal}] - Operational State of Device
Selects the media changers with the specified operational state.
[-error <text>] - Media Changer Error Description
Selects the media changers with the specified error string.
[-initiator <text>] - Initiator Port
Selects the media changers with the specified initiator port.
The following example displays information about all media changers attached to the cluster:
cluster1::> storage tape show-media-changer
Media Changer: sw4:10.11L1
  Description: PX70-TL
         WWNN: 2:00a:000e11:10b919
         WWPN: 2:00b:000e11:10b919
Serial Number: 00FRU7800000_LL1
Errors: -
Paths:
Node                      Initiator  Alias    Device State              Status
cluster1-01               2b         mc0      in-use                    normal
Media Changer: sw4:12.4L1
  Description: NEO-TL
         WWNN: 2:001:000e11:10b919
         WWPN: 2:002:000e11:10b919
Serial Number: 00FRU7800000_LL0
Errors: -
Paths:
cluster1-01               5a         mc1      available                 normal
