storage tape show-media-changer
Display information about media changers
This storage tape show-media-changer
command displays information about media changers attached to the cluster. By default, this command displays the following information about all media changers:
Device ID of media changer
Description of media changer
World Wide Node Name of media changer
World Wide Port Name of media changer
Serial number of media changer
Media changer errors
Node to which the media changer is attached
Initiator port which hosts the media changer
Alias name of media changer
Operational state of media changer
Functional status of media changer
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-device-id <text>]
- Device ID-
Selects the media changer with the specified device ID.
[-node {<nodename>|local}]
- Node-
Displays detailed information about media changers on the specified node.
[-description <text>]
- Description-
Selects the media changers with the specified description.
[-alias-name <text>]
- Alias Name-
Selects the media changer with the specified alias name.
[-wwnn <text>]
- World Wide Node Name-
Selects the media changers with the specified World Wide Node Name.
[-wwpn <text>]
- World Wide Port Name-
>Selects the media changer with the specified World Wide Port Name.
[-serial-number <text>]
- Serial Number-
Selects the media changer with the specified serial number.
[-device-if-type {unknown|fibre-channel|SAS|pSCSI}]
- Device If Type-
Selects the media changers with the specified interface type.
[-device-state {unknown|available|ready-write-enabled|ready-write-protected|offline|in-use|error|reserved-by-another-host|normal}]
- Operational State of Device-
Selects the media changers with the specified operational state.
[-error <text>]
- Media Changer Error Description-
Selects the media changers with the specified error string.
[-initiator <text>]
- Initiator Port-
Selects the media changers with the specified initiator port.
The following example displays information about all media changers attached to the cluster:
cluster1::> storage tape show-media-changer Media Changer: sw4:10.11L1 Description: PX70-TL WWNN: 2:00a:000e11:10b919 WWPN: 2:00b:000e11:10b919 Serial Number: 00FRU7800000_LL1 Errors: - Paths: Node Initiator Alias Device State Status ------------------------ --------- ------- ------------------------ -------- cluster1-01 2b mc0 in-use normal Media Changer: sw4:12.4L1 Description: NEO-TL WWNN: 2:001:000e11:10b919 WWPN: 2:002:000e11:10b919 Serial Number: 00FRU7800000_LL0 Errors: - Paths: Node Initiator Alias Device State Status ------------------------ --------- ------- ------------------------ -------- cluster1-01 5a mc1 available normal
