security snmpusers
Show SNMP users
The security snmpusers
displays the following information about SNMP users:
User name
Authentication method
Hexadecimal engine ID
Authentication protocol
Privacy protocol
Security group
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-vserver <Vserver Name>]
- Vserver-
If this parameter is specified, the command displays information only about the SNMP user or users that belong to the specified Vserver.
[-username <text>]
- User Name-
If this parameter is specified, the command displays information only about the SNMP user with the specified user name.
[-authmethod <text>]
- Authentication Method-
If this parameter is specified, the command displays information only about the SNMP user or users that use the specified authentication method. Possible values include the following:
community-SNMP community strings
usm-SNMP user security model
[-remote-switch-ipaddress <IP Address>]
- Remote Switch IP Address-
If this parameter is specified, the command displays information only about the remote SNMP user or users that belong to the specified remote switch.
[-engineid <Hex String>]
- Engine Id-
If this parameter is specified, the command displays information only about the SNMP user or users that use the specified engine ID, specified in hexadecimal format.
[-authprotocol <text>]
- Authentication Protocol-
If this parameter is specified, the command displays information only about the SNMP user or users that use the specified authentication protocol.
[-privprotocol <text>]
- Privacy Protocol-
If this parameter is specified, the command displays information only about the SNMP user or users that use the specified privacy protocol.
[-securitygroup <text>]
- Security Group-
If this parameter is specified, the command displays information only about the SNMP user or users that belong to the specified security group.
The following example displays information about all SNMP users:
cluster1::> security snmpusers Protocols Security Remote Vserver UserName AuthMethod EngineId Auth Priv Group Switch IP -------- ---------- ---------- ---------------- ---- ---- --------- ----------- cluster1 comm1 community 8000031504312d38302d313233343536 - - - readwrite cluster1 private community 8000031504312d38302d313233343536 - - - readwrite cluster1 snmpuser1 usm 80000634b21000000533296869 - - readwrite 172.2.20.91 vs1 snmpuser2 community 8000031504312d38302d31323334353632 - - readwrite - vs1 snmpuser3 usm 8000031504312d38302d31323334353632 - - readwrite -
