security snmpusers
Show SNMP users
The security snmpusers displays the following information about SNMP users:
User name
Authentication method
Hexadecimal engine ID
Authentication protocol
Privacy protocol
Security group
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <Vserver Name>]- Vserver-
If this parameter is specified, the command displays information only about the SNMP user or users that belong to the specified Vserver.
[-username <text>]- User Name-
If this parameter is specified, the command displays information only about the SNMP user with the specified user name.
[-authmethod <text>]- Authentication Method-
If this parameter is specified, the command displays information only about the SNMP user or users that use the specified authentication method. Possible values include the following:
community-SNMP community strings
usm-SNMP user security model
[-remote-switch-ipaddress <IP Address>]- Remote Switch IP Address-
If this parameter is specified, the command displays information only about the remote SNMP user or users that belong to the specified remote switch.
[-engineid <Hex String>]- Engine Id-
If this parameter is specified, the command displays information only about the SNMP user or users that use the specified engine ID, specified in hexadecimal format.
[-authprotocol <text>]- Authentication Protocol-
If this parameter is specified, the command displays information only about the SNMP user or users that use the specified authentication protocol.
[-privprotocol <text>]- Privacy Protocol-
If this parameter is specified, the command displays information only about the SNMP user or users that use the specified privacy protocol.
[-securitygroup <text>]- Security Group-
If this parameter is specified, the command displays information only about the SNMP user or users that belong to the specified security group.
The following example displays information about all SNMP users:
cluster1::> security snmpusers
Protocols Security Remote
Vserver UserName AuthMethod EngineId Auth Priv Group Switch IP
cluster1 comm1 community 8000031504312d38302d313233343536 -
- - readwrite
cluster1 private community 8000031504312d38302d313233343536 -
- - readwrite
cluster1 snmpuser1 usm 80000634b21000000533296869
- - readwrite 172.2.20.91
vs1 snmpuser2 community 8000031504312d38302d31323334353632
- - readwrite -
vs1 snmpuser3 usm 8000031504312d38302d31323334353632
- - readwrite -
