vserver export-policy rename
Rename an export policy
The vserver export-policy rename
command renames an export policy.
-vserver <vserver name>
- Vserver-
This parameter specifies the Vserver on which the export policy is located.
-policyname <export policy name>
- Policy Name-
This parameter specifies the export policy that you want to rename.
-newpolicyname <export policy name>
- New Export Policy Name-
This parameter specifies the new name of the export policy.
The following example renames an export policy named user_expolicy with the name read_only_expolicy on a Vserver named vs0:
vs1::> vserver export-policy rename -vserver vs0 -policyname user_expolicy -newpolicyname read_only_expolicy
