storage aggregate plex show
Show plex details
The storage aggregate plex show command displays information for the specified plex. By default, the command displays the following information about all plexes:
  • Aggregate Name
  • Plex Name
  • Is Online
  • Is Resyncing
  • Resyncing Percentage
  • Plex Status
To display detailed information about a single plex, use the -aggregate and -plex parameter.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-aggregate <aggregate name>] - Aggregate
Name of an existing aggregate which contains the plex specified with the -plex parameter.
[-plex <text>] - Plex Name
Name of a plex which belongs to the aggregate specified with the -aggregate parameter.
[-status <text>] - Status
Displays plex status. Possible values are:
  • normal
  • failed
  • empty
  • invalid
  • uninitialized
  • failed assimilation
  • limbo
  • active
  • inactive
  • resyncing
These values may appear by themselves or in combination separated by commas, for example, "normal ,active ".
[-is-online {true|false}] - Is Online
Selects the plexes that match this parameter value.
[-in-progress {true|false}] - Resync is in Progress
[-resyncing-percent <percent>] - Resyncing Percentage
[-resync-level <integer>] - Resync Level
[-pool <integer>] - Pool
The following example displays information about all the plexes for all the aggregates:
cluster1::> storage aggregate plex show
                    Is      Is         Resyncing
Aggregate Plex      Online  Resyncing    Percent Status
aggr0     plex0     true    false              - normal,active
aggr1     plex0     true    false              - normal,active
aggr1     plex1     true    false              - normal,active
aggr2     plex0     true    false              - normal,active
aggr2     plex2     true    false              - normal,active
5 entries were displayed.
The following example displays information about plex1 of aggregate aggr1:
cluster1::> storage aggregate plex show -aggregate aggr1 -plex plex1
Aggregate: aggr1
            Plex Name: plex1
               Status: normal,active
            Is Online: true
Resync is in Progress: false
 Resyncing Percentage: -
         Resync Level: -
                 Pool: 1
