storage aggregate plex show
Show plex details
The storage aggregate plex show
command displays information for the specified plex. By default, the command displays the following information about all plexes:
Aggregate Name
Plex Name
Is Online
Is Resyncing
Resyncing Percentage
Plex Status
To display detailed information about a single plex, use the -aggregate
and -plex
parameter.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-aggregate <aggregate name>]
- Aggregate-
Name of an existing aggregate which contains the plex specified with the
-plex
parameter. [-plex <text>]
- Plex Name-
Name of a plex which belongs to the aggregate specified with the
-aggregate
parameter. [-status <text>]
- Status-
Displays plex status. Possible values are:
normal
failed
empty
invalid
uninitialized
failed assimilation
limbo
active
inactive
resyncing
These values may appear by themselves or in combination separated by commas, for example, "
normal
,active
[-is-online {true|false}]
- Is Online-
Selects the plexes that match this parameter value.
[-in-progress {true|false}]
- Resync is in Progress-
[-resyncing-percent <percent>]
- Resyncing Percentage-
[-resync-level <integer>]
- Resync Level-
[-pool <integer>]
- Pool-
The following example displays information about all the plexes for all the aggregates:
cluster1::> storage aggregate plex show Is Is Resyncing Aggregate Plex Online Resyncing Percent Status --------- --------- ------- ---------- --------- --------------- aggr0 plex0 true false - normal,active aggr1 plex0 true false - normal,active aggr1 plex1 true false - normal,active aggr2 plex0 true false - normal,active aggr2 plex2 true false - normal,active 5 entries were displayed.
The following example displays information about plex1 of aggregate aggr1:
cluster1::> storage aggregate plex show -aggregate aggr1 -plex plex1 Aggregate: aggr1 Plex Name: plex1 Status: normal,active Is Online: true Resync is in Progress: false Resyncing Percentage: - Resync Level: - Pool: 1
