volume qtree rename
Rename an existing qtree
This command allows you to rename an existing qtree.
The automatically created qtree in the volume - qtree0, listed in CLI output as "" - cannot be renamed.
- -vserver <vserver name>- Vserver Name
This specifies the name of the Vserver on which the volume containing the qtree belongs.
- { -volume <volume name>- Volume Name
This specifies the name of the volume containing the qtree to be renamed.
- -qtree <qtree name>- Qtree Name
This specifies the name of the qtree to be renamed.
- | -qtree-path <qtree path>- Actual (Non-Junction) Qtree Path }
The qtree path argument in the format /vol/<volume name>/<qtree name> can be specified instead of specifying volume and qtree as separate arguments.
- [-newname <qtree name>]- Qtree New Name
This specifies the new name of the qtree. The new qtree name cannot contain a forward slash (/) and cannot be more than 64 characters long.
The following example renames a qtree named qtree3 to qtree4. The Vserver name is vs0 and the volume containing the qtree is named vol1.
cluster1::> volume qtree rename -vserver vs0 -volume vol1 -qtree qtree3 -newname qtree4
 PDFs
PDFs
