volume qtree rename
Rename an existing qtree
This command allows you to rename an existing qtree.
The automatically created qtree in the volume - qtree0, listed in CLI output as "" - cannot be renamed.
-vserver <vserver name>
- Vserver Name-
This specifies the name of the Vserver on which the volume containing the qtree belongs.
-volume <volume name>
- Volume Name -
This specifies the name of the volume containing the qtree to be renamed.
-qtree <qtree name>
- Qtree Name-
This specifies the name of the qtree to be renamed.
-qtree-path <qtree path>
- Actual (Non-Junction) Qtree Path } -
The qtree path argument in the format /vol/<volume name>/<qtree name> can be specified instead of specifying volume and qtree as separate arguments.
[-newname <qtree name>]
- Qtree New Name-
This specifies the new name of the qtree. The new qtree name cannot contain a forward slash (/) and cannot be more than 64 characters long.
The following example renames a qtree named qtree3 to qtree4. The Vserver name is vs0 and the volume containing the qtree is named vol1.
cluster1::> volume qtree rename -vserver vs0 -volume vol1 -qtree qtree3 -newname qtree4
