network ipspace rename
- PDF of this doc site
Creating your file...
Your file is ready
Rename an IPspace
Rename an IPspace.
-ipspace <IPspace>
- IPspace name-
The name of the IPspace to be renamed.
-new-name <IPspace>
- New Name-
The new name for the IPspace.
The name must contain only the following characters: A-Z, a-z, 0-9, ".", "-" or "_".
The first character of each label, delimited by ".", must be one of the following characters: A-Z or a-z.
The last character of each label, delimited by ".", must be one of the following characters: A-Z, a-z or 0-9.
The maximum supported length is 47 characters.
The system reserves the following names: "all", "cluster", "local" and "localhost".
The following example renames IPspace "ips1" to "ips2".
cluster1::> network ipspace rename -ipspace ips1 -new-name ips2
