ONTAP commands
cluster log-forwarding show
Display log forwarding destinations
The cluster log-forwarding show command displays log forwarding information:
  • Destination (IPv4/IPv6/hostname)
  • Port number
  • List of log classes
  • Facility
{ [-fields <fieldname>,…​]
| [-instance ] }
[-destination <Remote InetAddress>] - Destination Host
If this optional parameter is specified, the command displays information about the forwarding destinations with the specified host name, IPv4 or IPv6 address.
[-port <integer>] - Destination Port
If this optional parameter is specified, the command displays information about the forwarding destinations with the specified ports.
[-protocol {udp-unencrypted|tcp-unencrypted|tcp-encrypted}] - Log Forwarding Protocol
If this optional parameter is specified, the command displays information about the forwarding destinations with the specified protocols.
[-verify-server {true|false}] - Verify Destination Server Identity
If this optional parameter is specified, the command displays information about the forwarding destinations with the specified verify-server values.
[-facility <Syslog Facility>] - Syslog Facility
If this optional parameter is specified, the command displays information about the forwarding destinations with the specified facility.
cluster-1::> cluster log-forwarding show
Verify  Syslog
Destination Host         Port   Protocol        Server  Facility
192.168.0.1              514    udp-unencrypted false   user
